Papageno
New member
- West Sand Lake, NY
I have a situation where I have 2 separate loads that are powered by two separate line supply?s, but they share a neutral conductor.  I need to provide ground fault protection on each of these separate circuits.  I want to provide GFCI receptacles in line with each separate circuit.  Knowing that GFCI's cannot share a neutral on the load side of the receptacle, would pigtailing the shared neutral to each of the line-side neutrals allow the GFCI receptacles to independently function as required?  No load side neutral connection will be made, the terminals will be left empty.
