Two panel home setup and generator hookup
shawneegaming
New User
Oklahoma
IT
I'd like to wire up my panels with interlock breakers for a portable standby generator in the event of power outages. This is two story house and both panels are in the garage side by side. In the link below I have a rough hand drawn diagram of what I would like to do but I have some concerns.
1. It would be best to convert the generator to a floating neutral setup instead of a bonded neutral(default) correct?
2. The utility meter connection creates a tie between the neutral bars on both panels and in addition when those connect to the generator neutral(albeit floating) that may tie them together again. Is this an issue?
3. If I am running on generator power with this setup(utility power outage) and then utility comes back...is it an issue that my generator will be supplying a neutral to the entire system and also the utility neutral is back in an unknown state?
Thanks in advance. I've had a hard time finding a definitive answer on this stuff because it seems no matter how you hook it up that it probably does end up working but I would like to know the correct way.
I am closing this thread, in accordance with the Forum Rules
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the “Report” icon at the bottom left corner of the post.
