jorge copas
are two hot lines out of a 3 phase system called 2 phase?
any info will be apreciated
boboelectric said:2 PHASE might still be in use in the Philly area. A 5 wire thing,as i remember.
In all cases, the neutral carries the combined currents. However, when circuits are powered by different legs, the currents are vectorially added where they splice into the neutral. In algebraic form:eric1973 said:In a single phase panel a branch circuit using the same neutral, the neutral amperage is the combined amperage of both circuits. In a three phase panel, three circuits sharing the same neutral, is the neutral carrying all of the combined amps of the three circuits?
