Two pole afci circuit breaker
crtemp
Wa state
I can't find anything wrong with using these for MWBC's. Is there anything that stands out to anyone that suggests that I can't use them?
They say they are okay in "I-T-E" panels. Are these Siemens panels? They look exactly like Siemens breakers but they are made by Murray.
I basically just want to pull a 12/3 to the washer and then come out to the kitchen, and pull a 12/3 to the kitchen and then to the microhood. I can get these for cheaper than buying two single AFCI breakers.
A dp afci should work however when one trips then both circuits will trip. I would not use it unless I had to
Description:
The Southwire Romex SIMpull 250 ft. Yellow 12/2/2 NM-B Cable is meant for use in indoor locations where moisture and dampness are not present. This non-metallic sheathed cable offers a ground wire and a 600-volt rating. UL listed.
Along the same line, has anyone seen this in person? Home Depot has it listed online, a bit pricy though! Just over $200.00 for 250 feet. :happysad:
Siemens aquired Murray several years ago.
The murray line was consoledated into the Siemens line.
Apparently was not absorbed as deeply as the ITE, Furnas, or some other lines were. Those names are essentially gone other then for dealing with existing equipment, there is still equipment being made with the Murray name on it. Someday that name could disappear as well, may just be a legal thing that needs to run through a period that was determined at acquisition, then they can do whatever they want with it.
