This seems like an eacy question, but I can't find a simple answer in the NEC.
1. Are the circuit breakers that are used to protect circuits such as residental ranges, dryers, hot water heaters, etc required to be two pole (factory connected) breakers or can two single pole breakers be used?
2. What should or must be done about the continued use of two single breakers in older, existing (not new) residences?
