A/A Fuel GTX
- WI & AZ
- Electrician
I've got a two position meter socket on a house feeding one panel in the basement and one panel upstairs. There are no tenant mains on the meter stack and the service entrance conductors run on the exterior of the house to each panel. Can I run my GEC from the water pipe to the meter section and still run three service entrance conductors to each panel or do I have to go to a four wire feeder since the GEC is tied to the grounded conductor at the meter section? My thinking is that I can still run the three conductor to the panels since there is no disconnecting means in the meter section. Then I would install my main bonding jumper from the neutral bar to the load center enclosure as normal at each panel location. Am I on the right track here?
