In residential rentals in Baltimore inspectors are making the owners change three prong receptacles, that do not have a ground, to the two prong receptacles, which do not allow a plug with a ground to be plugged in. If you bond the ground screw to the neutral it will trick the inspectors plug tester into believing there is a ground. This saves the tenant from having to buy a three prong to two prong adapter. Usually they will just cut off the ground prong.
I know in theory it is dangerous to bond the neutral to the ground other than in the panel. Is it really though? I have done this in the house that I live in and don't see what the danger is.
