twistin214
- ohio/colorado
advice please. 400 amps run to residential garage. 200's parallel feeding to separate disconnects. one 200 was dedicated for house. (ran 4 wire)the other 200 feeds garage and into transfer switch for auto generator. so the generator panel also feeds a 80 amp sub panel to the house.(3 wire). i wanted 4 wire on both and keep everything separate but only got one. i also wanted to land one grnd rod for each. i'm getting confused on where to bond separate feeds? thanks and phone was run also from garage to house. pvc water feeds.
