George am&g
New User
- Los angeles
- Electrician
Two separate feeds dropped into two separate panels with there own meters side by side one panel at 200amp and the second panel being 100amp i grounded the 200 amp panel with #4 armor ground to two ground rods bonded to the the front main water line and a separate #6 armor ground for the 100 amp panel can i use the same ground rods i used for my grounding of the 200amp or do i need another set of ground rods for my 100amp and also bond to the front main water line on a residential lot with two homes in California
