(unless this is 70v line) you could blow up their amplifier. Connect two speakers in parallel like this and you cut the impedance in half. Look at the back of the amplifier for minimum impedance, then check the impedance on the speakers. If the amp says 8ohm min, and you connect two 8ohm speakers to the amp, the amp will either shut down on overload or blow up with any significant volume level. If the amp says 4ohm minimum and you connect two 8ohm speakers in parallel you will be ok.
Most of the constant voltage systems I see these days are 25 volt systems. Cheaper to install and safer for the end user to mess with. My experiences have been in school environments and you don't want 70 volt wires poking out of the wall boxes with the speaker missing.
