So there are two NEW sump pumps for sewage. One lead, one lag. a total of 4 circuits. each pump is 240 volts, 2 circuits each. when either is running the amperage is correct. However, when both run at the same time the amperage doubles, to 39-40amps.
When we got there the 30 amp fuses blew.
Any ideas as to why the amperage would double?
The well was not purged when the new pumps were installed. The old pumps were rated for only 15 amps.
