Two-wire GFCI
dhski04
New member
Batavia, IL
I have an outlet on my kitchen island. The previous owner ran 3-wire Romex to hook it up. When I tested the outlet to make sure it was GFCI-protected, I discovered that the ground wire is not running back to ground. I confirmed this by using my multimeter to run from the hot side to ground. I've been driving myself mad trying to find where the other end of the Romex is but I can't find the junction. I know that the GFCI/AFCI upstream is on the same circuit. I decided to treat it as a 2-wire receptacle and protect it with a GFCI without using the ground.
After hooking up the GFCI, we decided to test it by running a wire from the hot slot of the receptacle to ground (since my 3-prong tester won't test ungrounded GFCIs properly). When we did, there was quite a spark and the upstream GFCI/AFCI tripped as well as the 20A breaker, but not the GFCI that I was testing.
Why would the upstream GFCI/AFCI and breaker trip but not the GFCI I was testing? Is this normal, or is there an indication that the GFCI isn't functioning properly? The test button does work.
[FONT=&quot]I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the top right corner of the post.[/FONT]
