First let me 'sline a few things. I am a graduate retired EE but do not and have not worked NEC requirements directly for many years. Second, I think my original question on risk was perfectly valid. As I understand it, NEC did not explicitly state that tying ground to neutral was a no-no until 1996. This is a fairly late prohibition. Earlier, it was permissible to a tie groungd to neutral for a variety of reasons and one seemed to think it was risky. Until recent changes, neutral was tied to ground at the service panel so, it seems that there should be little risk. The claim that I read is that the neutral could be broken so causing a risk -- that I understand. But, a break in the gound doesn't cause a risk? Maybe I can't see all the possible connections.
I see and hear from a variety of building inspectors and electricians conflicting interpretations. For that, I don't have a lot confidence.
Finally, an ungrounded GFCI does provide some protection but such things as a shunt mode surge protector won't do what it is supposed to do. (I don't think shunt mode surge protectors don't work anyway but this is a different discussion.)
Does NEC allow an ungrounded GFCI with 3 prongs to be installed? That was my original question.
I came to this site because I can't find clear answers and explanations elsewhere.
I am a simple repair DIYER but beyond simple switch/receptacle replacement, I rely on ticket bearing electricians.
marion moon
marion moon
