yesterlectric
- Texas
- Electrician
Other than cost is there a reason not to install a type 1 SPD at the branch circuit level where a type 3 SPD would be acceptable to use? For example is there a higher clamping or let through voltage that comes as a tradeoff for the high fault current capabilities of the type 1 SPD which would make its use nearest to the equipment it protects less desirable? Asking because an engineer requested a particular type 1 SPD at a branch circuit.
