HO wants me to install a whole house surge protector, after having some electronics damaged during a power outage.
They have a small 125A split bus panel, original with the house from 1966, which is full. They don't need or want a service upgrade,
just the SPD added.
I don't think the ITE breakers are rated for two wires on the output. They have an existing GE surge protector wired to the dryer breaker in the upper part of the panel, and a CH one in the lower part wired to two different single pole breakers.
They have a new Square D SDSA1175 type 1 SPD they want installed. I was thinking of stripping some of the insulation off of the output of the "main" breaker, which feeds the lower half of the panel, and using split bolt nuts to wire the SPD to that, and then wrapping it with tape. That should give good protection to the 120V circuits, and is about the only good code compliant way I can think of installing it. Those wires, which are silver brazed to the lower bus, are part of the panel itself. Does connecting a SPD to them violate code?
just the SPD added.
