Do you have to remove siding to install these or can you cut out opening in siding and mount over existing siding ?![]()
Exterior Electrical Mounting Blocks (UL Listed) | Mid-America
Put Electrical Wiring In its Place Electrical Mounting Blocks: UL listed so you can make connections over the top of house wraps Holds fixtures up to 20 lbs. Easily hides wires for a clean, finished appearance Available in over 300 colors plus paintable Features color molded through so it...midamericacomponents.com
If you know how to mess with vinyl siding, it's not too hard, and the results are worth it.Do you have to remove siding to install these or can you cut out opening in siding and mount over existing siding ?
Usually, only the one or two pieces you'll be cutting. Tin snips and a razor knife should do it.I have used Arlington before and like them. Usually Installed before siding goes up. I now have someone wanting outside receptacle
installed and vinyl siding is already installed. I have seen plenty of vinyl siding installed but have never really messed with it myself. The issue being how would you install the boxes 4 or 5 rows up? Do you have to remove several rows?
Thank you!Usually, only the one or two pieces you'll be cutting. Tin snips and a razor knife should do it.
You can find videos about cutting openings in siding. A siding tool can be helpful:
