Type rx conduit
I've never heard of it. There is a 3RX enclosure listed in table 110.28. Where are you seeing this hub info?
Rx hubs
Rx hubs
Home depot stocks two different 2" hubs from siemens. One is listed as an "hs" hub, the other is listed as an "rx" hub. The bolt patterns are not the same, as one has a larger spread than the other. If "rx" refers to the hub mode, what is a hub mode? And under what circumstances would you use one over the other?
