Cleveland Apprentice
- Cleveland, Oh
Hello,
I purchased a manual transfer switch from Home Depot online and just received it this morning. It is a GE, SE rated, non-fused, single phase, type 3R, 100 amp rated. I plan on installing it between the meter and panel like you should. There's a problem already I've noticed with the neutral/ground bar inside the enclosure. There are 3 lug terminals. Now this is considered the disconnect switch and I believe there should be a total of 6 if I'm not mistaken. I believe I'm required to relocate and terminate both gec's from the panel (1 from grd rod, 1 from h20 line) to the neutral/ground bar of the transfer switch, now that leaves us with 4 open lugs. Now I have to connect the utility neutral, gen neutral, and neutral to panel, leaving 1 open lug where I would land my egc to the panel because now I would have to separate the egc and neutral. Another electrician told me to leave the gec's in the panel and keep the neutral/egc bonded there, but from past experience, I was told by AHJ that the gec's are always required to be terminated in the disconnect. Also, this transfer switch looks like a disconnect with a handle and has 3 handle positions; off, utility, gen. I was wondering how you guys would attack this? Thanks.
