We have an opportunity to install additional solar panels to an existing array.
The problem is that the homeowner wants to use an existing but never before used poly gas line as a raceway. I understand it is really not a raceway
unless it is identified as such in NEC, but what about cable suitable for direct burial such as type TC with d/b rating? It would IMO be ok without a raceway and direct buried; would pulling it into a non-NEC rated poly pipe change anything as long as fill, radius, etc were met? This is one continuous poly "tube" from a reel, in a straight run, as best as we can tell, with minimal bends. Direct burying the cable is not an option, as the customer does not want any more trenching. Using this pipe as a "raceway" is a prerequisite to getting the job; if it can't be done then the customer will not do the job.
We would like to get the job, but only if NEC can be met. Any thoughts?
