jeramiepluemer
- Wisconsin
- Electrician
Need c taps or h taps copper for milwaukee 6 ton crimper. Says it has o die and using u dies. Anyone help
I am a Generac dealer and want to get the milwaukee crimper but can figure out what will work with it. We currently us c tapsNeed c taps or h taps copper for milwaukee 6 ton crimper. Says it has o die and using u dies. Anyone help
Trying to see what head on Milwaukee crimper would work. I have put extensive effort into trying to figure this out. So I don't appreciate you comment.Is it a C die or a U die??
you haven’t put a lot of effort or information in your posts..
if it’s C dies they will insert in the back D3 slot.
U dies are for 12 ton hydraulic tools, W dies are for hand tools or the 6 ton unit your looking at.
there is an adapter to go from a W tool to a U die, but I wouldn’t recommend it. It’s tearing the tool up to crimp something too bug for the tool, adapter or not.
I think he was trying to help how about not being such a cuckTrying to see what head on Milwaukee crimper would work. I have put extensive effort into trying to figure this out. So I don't appreciate you comment.
Who do you think you are talking to like this? I wish you could say this to my face. Unreal. Never experience this before on this forum.I think he was trying to help how about not being such a cuck
You obviouslyWho do you think you are talking to like this? I wish you could say this to my face. Unreal. Never experience this before on this forum.
I thought I gave a great answer. I couldn’t figure out if you were using C dies or U dies. Your posts have both listed.Trying to see what head on Milwaukee crimper would work. I have put extensive effort into trying to figure this out. So I don't appreciate you comment.
I second thisI thought I gave a great answer. I couldn’t figure out if you were using C dies or U dies. Your posts have both listed.
Nobody is spelling we were Just trying to figure out if he was using a c h or u die in his crimper. Then ol dan wanted nuck up on yo boy.Enough. Stop the sparring.
I have to change the main panel to a sub panel and crimp the existing ground so I can extend it to transfer switch. What we have know is a 5/8 and 0 die. Sorry i am learning. I could use h taps copper. 4 and 6 awg copper wire is what i would need to crimpThe bg/d3 head is going to be the most versatile for grounding. What size wires are you wanting to crimp?
Just get a buttsplice (burndy) and use the standard dieI have to change the main panel to a sub panel and crimp the existing ground so I can extend it to transfer switch. What we have know is a 5/8 and 0 die. Sorry i am learning. I could use h taps copper. 4 and 6 awg copper wire is what i would need to crimp
If all you are crimping is that wire, then the bg (nose) die will be fine To crimp the cf44I have to change the main panel to a sub panel and crimp the existing ground so I can extend it to transfer switch. What we have know is a 5/8 and 0 die. Sorry i am learning. I could use h taps copper. 4 and 6 awg copper wire is what i would need to crimp
That tool is a good tool and will do what you need.MILWAUKEE 49-16-BGD3 M18 6T FIXED BG CRIMPING JAW
I just spoke with a guy at elecdirect and yes that is what he said. thanks. I order it and on the way. thanksThat tool is a good tool and will do what you need.
We own several.. (~20)
If you get one you will find you use it for more than just that One job.
the D3 forks for aluminum H taps for service entrances, and the smaller H taps (189 for example) use the D die that is added in the D3 slot
