mkgrady
- Massachusetts
Customer reports he has a DB cable run to a boat dock and the GFI that feeds it is tripping. The run is over 100 feet across a well kept lawn. I suspect it is not buried deep enough and landscapers may have cut into it during lawn edging. If that is the case I will recommend he run a new cable and bury it 24 inches or run PVC and bury it 18 inches.
If I am wrong, and it is buried deep enough, is there a way to find the fault? I am familiar with thumpers but I would not use that on 600 volt cable.
