Todd0712
- Cape Coral FL
Under Art. 340.10,1,3. it states that UF cable can be installed "in wet, dry or corrosive locations under the recognized wiring methods of this code". I have installed UF cable on a wooden boat dock to carry my lighting branch circuit from piling to piling. My AHJ is claiming that the code book does not say UF cable can be installed under the deck of a boat dock. The cable is running through the girder joists and also stapled with SS staples. Am i reading this wrong? I believe the cable is installed per a recognized method and the cable is rated for wet locations and sunlight.
If this is not correct, can someone please tell me where I can find the code that does not allow it?
thank you
Todd Patrick
thank you
Todd Patrick
