Bobhook149
using table 300.5 column 4 does this mean you can use UF if it is GFCI protected and 120v in a residence at a depth of 12''??
Thats how I read it, 20A or less.
I agree with the others, however if this is a common area to some townhouses or condos, then this rule should not apply. If it is strictly for a residence then I totally agree.using table 300.5 column 4 does this mean you can use UF if it is GFCI protected and 120v in a residence at a depth of 12''??
