WV Sparktition
- Charleston, West Virginia
I have a collegue who installed 6-3 w/g UF cable under siding J-channel, about 80 feet to a Hot tub disconnect, then from there he protected it with liquid tight flex to underground, then from underground it entered the hot tub. A home inspector is critizizing it. Is there a code saying you cannot run UF for hot tubs, or un protected without conduit along a house.
To my knowledge I thought UF was similar, hence similar, to SE and it could be run on the outside of a dwelling without protection.
