You'll find an excellent discussion from the the man himself, H.G. Ufer, in Appendix B of Electrical Grounding and Bonding based on the 2005 NEC by J. Phillip Simmons published by Thomson, Delmar Learning.Originally posted by bphgravity:
I would be interested in reading a study on this.
I have seen the after effects of that, one of our customers building was struck by lighting and a large section of the cement parapet was blown apart. It was lucky no one was around as chunks of concrete came raining down from about the 6 th floor level.Originally posted by bphgravity:
A high intensity strike is capable of passing through concrete itself with or without the conductive rebar in place. This current super heats the moisture within the cement causing it to turn to steam which rapidly expands possibly cracking or blowing apart the concrete.
