BMacky
- Foster City, CA
I am working on a new construction project where the structure is a "pool pavillion" located next to an in-progress pool installation. When I showed up to look at the job, the GC noted he had left a Ufer (stranded #4) in the stud bay where the sub-panel will be installed in a utility room.
Here's some basic known data:
- The structure will be fed from a new main located at streetside (rural area in N. California) with an underground feed to the sub-panel located in the structure's utility room. The underground work will be sub'd out, but assume it to be a typical 400A meter/main with distribution.
- The pool equipment will be fed from the structure's sub-panel
- The structure has no bedrooms or kitchen, etc. Only a bathroom, sitting area, bar and utility/laundry room. I add this as it may not be considered a dwelling unit, unless the definition of such covers this type of structure.
Here's some assumed data:
- the ufer is tied into rebar in the structure foundation only, not the pool or pool deck rebar.
Here are the questions:
- What sort of grounding scenario would be totally code-compliant here?
I assume (haven't researched this yet, and generally go over it with pool installers) that the pool deck and associated pool rebar grid will have to be bonded to the sub-panel. Please consider this as well.
- The ufer (stranded #4) left in the stud bay where the sub-panel shall be installed appears to be too short to reach the panel if it is to be installed at a proper height. Any suggestions on how to work with that scenario? I have not crawled under the sub-floor yet, so am not sure if there is additional length to pull or not.
Thanks for any/all code references that apply!
