dt4gotten1
- Riverside, CA USA
When installing a 200amp single phase sub panel with a load of 175amps, can the sub panel be tapped off the 200amp single phase main service using a tap rule, or is a bigger service required, and feed it with a 200amp breaker. Also the distance from the main to the sub panel is 50 ft. One more thing, is rigid pipe burial depth still 6 in. under a concrete driveway.
