capybara
- california and afghanistan
I work in an office building and all the loads here are non-linear producing harmonics: fluorescent lights, computers, and small
split unit HVACs (heat pumps.) Almost every day, our UPS start beeping like they would if the power was off. But the power isnt off -
I measure it at 227 - 231 volts on a British system (nominal would be 230v 50hz) and I measure frequency at 50.3 hz. Neutral to ground I measure as 1.6v. Whatever is happening cant be measured on a regular Fluke and lasts for 5 minutes maximum usually. Not having a good RMS meter or anothing other than a regular Fluke meter, I think its a harmonics problem and im considering buying some sort of harmonic filter to try to fix it. Do this sound about right? :?
