kyle_panel
New member
i am asking for electrical expert to help me here. pls see below
give specification
120/1/60 incoming power input, then being step down by a control power supply(approx 50watt ) to 24VDC to feed PLC. This control panel is mixed with 120VAC and 24VDC control voltage components (AC-contactor, overload, relay, DC-PLC)
should i ground both AC ( from G terminal of power supply) and -V ( from -24VDC terminal) to the baseplate of the control panel??? Both circuits contains field wiring terminals.
I believe it some cases, it just need to ground the 120V AC circuit but not the 24VDC, right?
note: control power supply contain terminals of L,N,G,-V,+V
thanks
give specification
thanks
