Open Neutral
- Inside the Beltway
- Engineer
Andrew S. Tanenbaum:
The nice thing about standards is that you have so many to choose from.
So I'm seeking Current Transducers {w/4-20mADC out} for a project. There's a 400A 3ph 208 feed via "2 sets of 4#3/0 THWN 1 #2/0 CU (G)"
The transducers must slide over the paralleled phases. The CTD-400E2 I favor so far has 1.56" diameter donut hole err sensing orifice. I swag the #3/0 at .579" diameter each so think 2 will pass. I assume the PE will want them in a NEMA cabinet, but that's his dept; mine is just spec'ing what they will install.
Then it gets more interesting. Several firms sell {seemingly identical} CTD-400E2 units under their brand names, but some say the units meet UL, others say they meet UL/CE. (And if I were to want 0-10VDC out [into 10 MΩ, yes ten....] vs 4-20, those don't have UL but do have CE.)
My question:
Will the PE & AHJ on this job care about CE?
ps: the above feed is from the 100 KW backup generator to the Emergency Distribution Panel.....in a residence.
My question:
