UL Listing for MV Splice-kits
Woobie
Los Angeles, CA
Electrical Engineer
Is there a UL listing for Medium Voltage (12kV) splice kits (e.g. a T-body splice)? The most common manufacturers don't have one listed (no pun intended) on their cutsheets, so I wonder if there is one.
I understand the standard is UL 1072 for cables that also applies to connectors. I believe this is listed https://multimedia.3m.com/mws/media...-iii-indoor-outdoor-terminations-brochure.pdf
As of the NEC 2023 Section 315.6 Listing Requirements requires
Type MV cables, type MV cable joints, type MV cable terminations, connectors, and associated fittings shall be listed. The listing requirement for Type MV cable joints, cable terminations, and connectors shall effective January 1, 2026.
