The AHJ is asking me to provide UL listing for an underground (outdoor) mounted optical cable.
Can someone help with the code section or requirement for this AHJ request?
I did not see even an UL standard for this.
Thanks,
What about the 50 feet you are allowed?Thanks. This could be a path, but in case the cable is not foun in the list.....my question still apply. NEC-2008 art 770.48 is talking about unlisted optical cable entering the building. Can I suppose that the outdoor cable are exempt from listing...and if so...where is this article?
If the cable in question is not owned by a communications utility, it is covered by the NEC and is subject to permiting and inspection per the rules of the local AHJ. While there is no specific code section that would require this cable to be a listed product, 110.2 lets the AHJ require the use of a listed product.Yes, I would say its exempt.
Its not electric, and its not inside the building. Its outside the scope of any building inspection, because its not safety related. (Although, there could be "right of way legal" issues that could be within the scope of the AHJ's review.)
The NEC covers this non-electric installation, therefore 110.2 applies.Don:
How can 110.2 apply to a non-electric installation outside a building?
770.48 is titled "Unlisted cables and Raceways Entering Buildings", and since unlisted cables are allowed to go 50' into a building, it seems obvious to me that the intent is to allow unlisted cables outside since the paragraph doesn't place any limitation on outside cables.
