Asif Mirza
Classify the following markings in terms of "Most Safe":
UL LISTED
UL Classified
UL Recognised
UL LISTED
UL Classified
UL Recognised
Asif Mirza said:Classify the following markings in terms of "Most Safe":
UL LISTED
UL Classified
UL Recognised
jim dungar said:One is not "most safe". Each term has its own purpose.
UL Listed means the item can be used just as it is.
UL Recognized means the device must be used with a second device (for example, a plug-in unit must be used with some type of base device).
UL Classified means the device is tested for a limited application (for example a classified circuit breaker is tested for use only in specific panelboards).
