Randy Kellum
New member
- Houston, Tx USA
Is a UL listed electrical enclosure automatically qualified for CSA, or does one have to get the CSA listing even though the requirements are identical?
While I agree with most of the post, it isn't entirely true. This thread, starting at Post 4, is an example.... If you are using equipment in the US, then we have a slightly different requirement; that equipment be listed by any NRTL, Nationally Recognized Testing Lab. UL is the most common and well known one, but CSA is also acceptable anywhere as well, with or without the UL mark...
:bye:While I agree with most of the post, it isn't entirely true. This thread, starting at Post 4, is an example.
OSHA says it is...Basically, a simple CSA mark is not NRTL as far as FedOSHA is concerned. But I can't imagine a typical "ordinary location" enclosure without dual certification either.
Yes - so? I didn't say CSA wasn't a NRTL; I said a simple CSA mark doesn't indicate the product was a NRTL mark acceptable to FedOSHA. These are the typical FedOSHA NRTL marks that indicate a product has been certified to an American National Safety Standard.
The simple presence of the CSA mark does not, by itself, indicate what standard the device was tested against. That will potentially change from one country of use to another, requiring the same NRTL to test against different standards to, for example, add the US designation to the mark.Yes - so? I didn't say CSA wasn't a NRTL; I said a simple CSA mark doesn't indicate the product was a NRTL mark acceptable to FedOSHA. Not all NRTLs are permitted to certify everything either.
I had thought so too, because it used to be that way. It changed a few years ago.an explanation of various UL marks.
http://www.ul.com/global/eng/pages/corporate/aboutul/ulmarks/mark/marks-for-north-america/
I did not realize there were so many.
I had thought the CUL mark was both, but it turns out the CULUS mark is both, as another poster mentioned. One learns something new everyday.
Unless you are a UL listed electrical enclosure fabricator, you cannot. You can contact one though, they MIGHT be persuaded to help you out.How can I UL list a custom electrical Panel cover for electrical enclosure.:?
