We are having a real issue with using the 408a method to determine our SCCRs. Our problem is that our panels operate heaters using SSRs and run at about 100A in the on state. If you are familiar with table SB4.2 you know that this table is nothing but a major hindrance if youre above 30A. Bottom line is...this table gives all of our panels a 5kA SCCR, when the fact is that high-speed J fuses adequately protect the SSRs based on the manufacturers data. I understand why UL is using blanket ratings, but IMHO it is too restrictive and NEC should exempt industrial heater controls from having to use table SB4.2. A more sensible approach would be to require on-panel LABELLING as to proper and specific fuse replacements and let us use fuse ratings based on reality, not blankets. What do we have to do to get this exception written into NEC 409?
