I have a VFD powered motor. The contactor I am using to bring 480V power to the line side of the VFD has an SCCR of 5KA, unless used with an approved circuit breaker combination.
All of the circuit breaker combinations, however, are UL508 CB's. If I use a UL 489 breaker instead, my SCCR will be 5KA. I need to use a UL 508 breaker to increase the SCCR. Can I use a UL 508 breaker on a motor load if a VFD is on the same branch circuit?
I know if the VFD was not there, then I could use a UL489 or UL508 breaker, but with the VFD am I limited to just the UL 489 breaker at that point?
