UL508A label in aluminum foil
larsahl
Sweden
Hello,
Does any one knows if there is possible to get UL508A labels that can withstand water and alcohol for wipe off cleaning?
I was think of label in aluminum foil or something similar.
If there is it would be possible to put the label outside the electrical cabinet instead of hiding it inside.
Hello,
Most certainly.
See the following site for an example (not an endorsement):
http://www.american-nameplate.com/underwriters-lab.html
But are you referring to the label (nameplate) that UL requires on the OUTSIDE of the box, or the one UL provides for you with their official symbol that usually goes on the INSIDE, on the back panel? Because the outside nameplate / label can be anything you want it to be. I used to just engrave a lamacoid nameplate with all of the required information.
