I have a cabinet with semiconductor fuses protecting a VFD inside, fuse has a 100ka IR and all component inside has a 10ka IR. UL508A SB4 talks about analyzing peak let thru values to determine SCCR, I understand the rationale that components IR after the current limiting device must be rated higher than the peak let thru but UL508A only talk about Class CC, K, G, L, J, and R and using the tables to determine the peak let thru, it doesn't mention semiconductor fuse which has a lower I2t values and is current limiting. Can I use the semiconductor fuse peak thru current to determine my cabinet rating even though its not mentioned in the SB4.2 table.
