I'm a bit confused on UL98 vs UL508 switches. Can a UL508 rotary cam switch be used (open transition, ON-OFF-ON) to switch a load between two different supplies? Each supply has a UL489 breaker upstream of the switch. Some of what I have read seems to indicate that UL508 switches are only for motors, other info I have come across seems to indicate this is ok as long as the 508 switch is not the only disconnect.
