Bikeguy
- Wilmington, Delaware, USA
We have been debating this question and looking for guidance on classifying Ultrasonic sealing with no luck. I am hoping someone might provide guidance. For those who don't know how ultrasonic sealing works I'll provide the dumby's guide.
In our application of bag sealing, an ultrasonic transducer converts elec energy into sonic mechanical movement. This is tranmitted through a mechanical amplifier (specially shaped metal) into a horn (another piece of metal) The horn then compresses two layers of a poly bag between itself and the anvil and delivers the sonic energy into the plastic causing the molocules of the plastic to vibrate, heat up, and fuse. There is no actual heat delivered from the horn or anvil. Any heat realized is conducted into the horn and anvil as a result of fusion
The debate has been if the horn and sealing surface fall within the jurisdiction of the code (NEC/IEC) for the purpose of classifying a component for Cl II Div 1. The transducer, the actual electrical device does not necessarily get hot.
If the transducer can be ratedhermetically sealed and intrinsically safe and all other electrical wiring and connections are per code for this class, then does the jurisdiction stop at the transducer and the temperature of the sealing surface is not part of the classification consideration but should be taken up as a separate safety consideration for the area.
I am arguing that the temperature at the sealing surface should not be a factor in considering a piece of equipment for this purpose.
Have there been an interpretations or writings on the topic?
I hope someone has some experience with this.
