waltermitty
New member
we installed a 480VOLTS 3 phase 5HP pump. The pump has a 2 wire high temp sensor in series with the overload heaters in the starter which is 830 feet away from the pump. With the pump not running we recorded a voltage of 625 volts from the temp sensor to ground ! Can anyone explain what is going on?
