GerryB
- woodbridge, ct. USA
I wired a shed for my brother. Came up to a corner in the shed, put a GFI and fed thru the load side for a switched outlet and another outlet. He wanted an outdoor outlet and as I was installing a regular TR receptacle (since it was already gfi protected) I remembered the outdoor receptacle is supposed to be WR also. So I put in a second gfi. The outside gfi is now also protected by the inside gfi which I don't like to do, but I didn't want to rewire everything or put in more gfi's for the other two plugs. I can see this being an issue to consider. Do they make a receptacle that is WR but not GFI?
