LalitKumar
- Qatar
In our operation at factory, we have total six rings of load(heating elements) fed by a 5MVA transformer, DY5 33kv/500-2500V (5tapes). Each secondary phase is connected to equal load of heatingelement rings through thyristor and we recently carried out a thyristor firing program change that allows even one ring in operation and supporting the production. Earlier one ring stops due to any genuine interlock/reason caused all the rings down - loosing production.
Now after program change, sometimes one ring trips and loses power and then we have to re-start it within15-20minute.
Recently we have undergone one phase failure of one such transformer under operation. I believe this type of switching program change which allows other phase ON, may have caused neutral shift and increasing high current in remaining phases for say 10-15 minutes and thus this transformer burnt. Even after re-startup we graduallyincrease the current at faster rate to reach up to the last ampere value beforetripping. So unbalance situation lies roughly 3-4 hours.
How much unbalance typically a transformer is allowed which supposed to run at equal loading ? our relay at upstream 33kV side is set at 2times of FLC for 51N.
