I am involved in designing a distribution system for a small pump house. My question relates to dealing with unbalance in a three phase system and keeping the system as balanced as possible.
The service entering into the building is 480V - 3 phase (unsure if delta or wye). This will be split to some balanced 480V 3 phase loads (motors) and to several single phase 120/240V loads in a 100A panel. Intuitively the best choice would be to use a 45kVA 480V to 120/208 delta-wye transformer to source these single phase loads however, the loads require 240V (cannot operate at 208). We were considering using a 480V delta-delta 120/240V center tapped transformer however it is my understanding that these transformers are severely de rated at for 120V 1 phase loads. Our loading on 120V circuits is relatively high- We'd have to oversize the delta-delta transformer to 75kVA to keep it under the recommended 5% kVA limit for 120V circuits. What about unbalance due to the 240V 1 phase circuits?
Would it be better to pull off of 1 leg of the 480V service, step this down to 120/240V with a single phase transformer at the entrance or should we stick with the oversized 75kVA delta-delta transformer further down the line? My concern is keeping the system as balanced as possible. Is it better to cause unbalance at the 480V level i.e. pulling off of one leg of the 480V service or better to keep it balanced down the line and cause unbalance at the lower voltages? I don?t have any experience with any buck boost type transformers? Are these an option? I?m open to suggestions. Thanks very much.
