AHarb
- Atlanta, GA
I know there are plenty of threads on calculating the neutral current. I even found one that had a spreadsheet which calculated the neutral current based on given power factors and current values. I cannot figure out how to calculate the neutral current if we are give the phase angle between the currents and voltages (theta) and the current values.
I know the formula is In = sqrt(Ia^2 + Ib^2 + Ic^2 -Ia*Ib - Ia*Ic -Ib*Ic) if you're at unity (theta = 0 degrees). I've tried working it out using vector math and here is the best I can come up with for an unbalanced load.
Sqrt ( ((Ia*cos ?a) + (Ib*cos?b) + (Ic*cos?c))^2 + ((Ia*sin?a) + (Ib*sin?b) + (Ic*sin?c))^2)
I know that I'm doing something wrong because plugging in 0 degrees for theta does not work out correctly. Can anyone help me correct the formula?
Thanks in advance. Sorry if this is repetitive and somewhere else on the forums. I was unable to find the answer.
Edit: I just realized it didn't like my symbol for theta. The "?" in the formulas should be theta.
