EEC said:If there is 40 amps of unbalanced current on the neutral. Can you read that current with clamp over amprobe.
EEC said:If so, back at transformer, where does the 40 amps go on Delta/pri-Wye grounded secondary?
Some of it flows into the Phase A secondary winding, and some into the Phase B, and the rest into the Phase C. And moment by moment, throughout the "60 times per second cycle," how much goes which way will change. But the simple truth is that with four wires (and no other stray paths) leaving the transformer, any current that leaves on one must necessarily return on one or more of the others. At all moments, the sum of the currents on the four wires must equal zero amps.EEC said:. . . where does the 40 amps go on Delta/pri-Wye grounded secondary?
Hmm... more accurate and perhaps better understood as modified?charlie b said:
...At all moments, the sum of the [instantaneous] currents on the four wires must equal zero amps.
Smart $ said:Hmm... more accurate and perhaps better understood as modified?
Sidenote: When using RMS current values, one must account for phase relationships to make the sums equal zero.
Hmm...weressl said:Hmm...... could you explain to me what is the difference between 'all moments' and 'instantaneous'?
roger said:to have any unbalanced current on the neutral the neutral conductor has to be common to more than one ungrounded (hot) conductor on opposing ends of the winding
If I were to answer in his behalf, I'd say his statement stands as made.Ranch said:Roger - might you want to consider triplens?
