Hi folks,
I'm a brand new member and am troubleshooting an interesting problem that would be great to get some opinions on. The residence has a small 6K solar hybrid inverter. The main utility feed connects through an ATS (for a generator) and then to the inverter. When the inverter is in 'grid mode' it essentially is a pass-through for the power back to the main panel. The loads on the panel are 240V pumps and some 120V outlets. In 'grid mode' the 120v legs are balanced and happy. When the inverter switches to create 240v from the batteries the 240V output in the panel is just fine but the 120v legs are unbalanced (eg. 185v and 24v). So the 240V pumps continue to work normally but the 120V outlets are unusable. The specs for the inverter specifically instruct that if you use 240V for your loads or a mix 240/120, you connect only the two hot wires for the output (i.e. no neutral). This doesn't seem to be a problem for the 'grid mode' pass through, but seems to be a problem for the inverted battery power. Thoughts?
