Scenario: A building or structure or renovation is designed and sealed or approved. Construction is under way.
An inspection is being conducted on some element of the work and the inspector says the installation or item or whatever is not adequate or correct or does not comply with "The Code" (ex the inspector always requires 12 ga Cu in this installation even though 14 is spec'd and OK by the Code)
But the element being inspected agrees with the constructor's/installer's interpretation of the applicable Code or the approved drawings.
What happens? What can be done?
Does one litigate, cave in, call Congress?
[ August 18, 2005, 08:04 AM: Message edited by: iblittljn ]
