willc86
New member
- colorado springs
Hi all!
ok...so...I am undecided what to use to power up this detached shed, which is 70 feet away from the main panel. I obviously want to go the safest route (shed is 200 square feet)
route 1 -
Use a double pole 60amp with #6-3 UF wire to feed a 60amp sub panel in the detached shed? (wire will be buried)
route 2 -
use a double pole 30amp 10-3 wire UF rated to feed a 50 or 60amp sub panel in the detached shed
what I plan on using in the shed -
3 security cameras
5 outlets (GFCI)
power tools such as table saws and vacuums
small TV and leave batteries charging
thats about it....
what is the best route?
route 1 -
route 2 -
3 security cameras
5 outlets (GFCI)
thats about it....
