username5000
- Poplar Bluff, MO USA
I recently installed 24 (total) under and above cabinet lights in a customers home. They are Patriot lighting 16" and 12" slim (model# 0033-0011). They are 120v 10w dimmable and in the specs it says "internal driver-no external driver needed." The dimmer switch is a Lutron Ariadni 250w led dimmer. No matter what... they flicker. But just barely and for only 3-5 seconds at a time then go back to "normal". Its very subtle but its enough that the customer doesn't like it.
So..the setting
Neutral is in the switch box so I have 120v in switch box.
leaving switch box out to first light is 12-2 romex w/ ground. It comes out a little hole just below the cabinet.
Another 12-2 w/ ground goes from 1st cabinet to the second cabinet. Daisy chained from cabinet to cabinet to cabinet.
There is a thin junction box below each cabinet to catch the daisy chain and the lamp cord that plugs in to the light.
Some cabinets require a 12" and a 16" light to be installed. In these cases only one light is hardwired in the box. The other is fed from a linking cord allowing one light to output 120v to the other. Specs say a max of 20 can be linked together. In this installation no more than two are ever linked.
What I have tried
First I removed the switch and just wire nutted the hot and switch leg. Still flickered.
I turned off every breaker in the house except for the circuit in question and turned off each under cabinet light with the little switch on the light itself. (on/off type not hi/lo/off)
Every light, individually, still flickers. With the switch bypassed.
Has anyone ever come across something like this before? I know it says no driver needed but would adding one help? I ran the two extra wires just in case but since the product says none needed....
Any help or insight would be appreciated
Thank you all
So..the setting
What I have tried
Thank you all
